Mosaic68
Mosaic68's Achievements
Member (2/11)
10
I'll ask for more details. My own reasoning for HG issues: 1. Running with empty radiator 2. Rough start 3. First indi visit trying everything to remove #3 misfire and getting nowhere - trusted mechanic, I believe him. 4. Carbon in reservoir Why does one need more info? What else would cause the above. There's at least 1 internal head gasket leak, and with the engine being pegged, I think both heads should be leveled. As far as more damage is concerned, we'll see. As I said, the engine runs fine. I'll demand to see the block with the heads off for verification, at least I'll be able to see the sleeves and piston faces, and if they don't clean the block faces off I can see where possible leaks were.
Since explainations were through a friend and I was freaked out when explaining them here are the symptoms: Before any symptoms, radiator run dry, engine temp gauge pegged for ~1 block. 1. On startup, rough idle for ~15s and causes #3 cel misfire - the 15s has grown over last 2 weeks was intermittent, isn't anymore and is getting progressively worse. 2. Car runs fine otherwise - I cannot speak to power or response, though little I've ridden/driven doesn't seem to dog. 3. Eventually, w/in or less than 1 week the cel blinks. 4. Coolant reservoir has chunks of black soot in it. from the shop(s): I. first Indi mechanic: Both plugs and wires have been replaced and injector cleaner used to no avail. I'm guessing he found coolant in the cylinder by removing spark plug? Can't speak to it, just know he emptied all tricks to fix #3 misfire cel over a day and half. I. dealer: compression test shows likely IHG leak on all four cylinders II. Indi 2: relative compression test shows there is most likely integrity in rings and pistons (no holes and no sprung rings - unless they either all have holes or all have sprung rings), also based on how it runs there are no strange noises, slapping, diesel type noises or other leading him think there are any troubles with engine internals. As I witnessed, it runs smooth. We'll see when they open the engine up. I cannot speak to online forums experience at not hearing of all four having IHG failures, myself guessing it's not a frequent result but probably happens given a possibly uneducated woman and her daft idiot husband. Both Dealer and Indi were not surprised, and neither was a manager from this place: http://www.subaruguys.com/ This could be wrong, we'll know in the next day or two.
OK. So with, I think he called it a 'relative compression check', they believe the short block to be OK. We're getting both HG's replaced, milling the heads flat. As the motor is removed, we're replacing water pump, front and rear seals, Timing belt, plugs, radiator flush, new set of coolant hoses... for $2900. Asked about the torque converter seal, manager is looking into it - asked them if they new how to install, they're getting back to me. Finish time of Friday evening, 3 yr/36,000mi warranty. Not surprised if you guys are going to tell me this is high... not feeling like I have many options here in G.R. MI. As far as doing all the components, like water pump, etc, I really don't have the facilities to do this stuff myself, and since the motor is removed, why not.
