Mosaic68
Everything posted by Mosaic68
I'll ask for more details. My own reasoning for HG issues: 1. Running with empty radiator 2. Rough start 3. First indi visit trying everything to remove #3 misfire and getting nowhere - trusted mechanic, I believe him. 4. Carbon in reservoir Why does one need more info? What else would cause the above. There's at least 1 internal head gasket leak, and with the engine being pegged, I think both heads should be leveled. As far as more damage is concerned, we'll see. As I said, the engine runs fine. I'll demand to see the block with the heads off for verification, at least I'll be able to see the sleeves and piston faces, and if they don't clean the block faces off I can see where possible leaks were.
Since explainations were through a friend and I was freaked out when explaining them here are the symptoms: Before any symptoms, radiator run dry, engine temp gauge pegged for ~1 block. 1. On startup, rough idle for ~15s and causes #3 cel misfire - the 15s has grown over last 2 weeks was intermittent, isn't anymore and is getting progressively worse. 2. Car runs fine otherwise - I cannot speak to power or response, though little I've ridden/driven doesn't seem to dog. 3. Eventually, w/in or less than 1 week the cel blinks. 4. Coolant reservoir has chunks of black soot in it. from the shop(s): I. first Indi mechanic: Both plugs and wires have been replaced and injector cleaner used to no avail. I'm guessing he found coolant in the cylinder by removing spark plug? Can't speak to it, just know he emptied all tricks to fix #3 misfire cel over a day and half. I. dealer: compression test shows likely IHG leak on all four cylinders II. Indi 2: relative compression test shows there is most likely integrity in rings and pistons (no holes and no sprung rings - unless they either all have holes or all have sprung rings), also based on how it runs there are no strange noises, slapping, diesel type noises or other leading him think there are any troubles with engine internals. As I witnessed, it runs smooth. We'll see when they open the engine up. I cannot speak to online forums experience at not hearing of all four having IHG failures, myself guessing it's not a frequent result but probably happens given a possibly uneducated woman and her daft idiot husband. Both Dealer and Indi were not surprised, and neither was a manager from this place: http://www.subaruguys.com/ This could be wrong, we'll know in the next day or two.
OK. So with, I think he called it a 'relative compression check', they believe the short block to be OK. We're getting both HG's replaced, milling the heads flat. As the motor is removed, we're replacing water pump, front and rear seals, Timing belt, plugs, radiator flush, new set of coolant hoses... for $2900. Asked about the torque converter seal, manager is looking into it - asked them if they new how to install, they're getting back to me. Finish time of Friday evening, 3 yr/36,000mi warranty. Not surprised if you guys are going to tell me this is high... not feeling like I have many options here in G.R. MI. As far as doing all the components, like water pump, etc, I really don't have the facilities to do this stuff myself, and since the motor is removed, why not.
Ok. at most, 2. but I'm gonna stick by 1. We were just headed out on a road trip and turned around. This motor has seen a rough year and has died quietly. The longer story is that we started having #3 cyl. cell code much earlier in the year - Mid summer. Driver side HG recall was done 2/06, I'm guessing it started leaking (slowly) soon after the recall, wife was bringing into valvoline for oil changes, valvoline most likely topped it off every visit - if the dealer properly filled it to begin (that is working the air bubbles out)- I question this b/c I had to tighten all the fuel hoses b/c of leakage (puddling) and am fairly confident they DIDN'T machine the head or check it for that matter b4 reassembling. Btw, "one head gasket" was meant to be driver or passenger 'side'. Back to the motor, my guess is that the #3 cylinder is the worse of the four and was the first cylinder to fail since it produced the cel on startup intermittently about mid summer - I originally thought it was spark plug failure. Tried that, I thought it went away after doing that... (I had no idea there would be a connection between the two). Went on a lengthy stay in Spain in August/Sept, returned, cel for #3 either was there already or re-appeared, but NO other symptoms. Like Scott said, there are NO outward signs that there are HG issues here, except for rough start up and #3 cel. Earlier this summer through to winter, there were no signs! And even then, the signal was a rough idle on startup and #3 cel. Obviously, the HG was ruined once the cel showed, motor probably fried within a month or so? Nothing until empty radiator in mid november, then after that, EVERY startup was rough. I'll admit I'm guilty of just letting it run on auto and hadn't grasped the severity of subaru HG issues or subaru sensitivity to coolant air pockets, I've never had slow coolant leaks on past cars, though, I've never had my cars worked on by anyone but ME. Expensive lesson not to be repeated. I have no idea how the dealer checked each cylinder, probably should have asked, but since I don't want them to touch anything from here out, I'm bringing it to the indi - which I hadn't found until today. I just wanted a quick sanity check. And yes, I'm sure it sounds strange that if I didn't trust them why have them sanity check it, like I said I hadn't located ANY in G.R. up to today that was the least familiar with subies, besides until late last week, I didn't think the motor was as bad as it was... I'll probably have him run his own diagnostics to the point of confirmation, most likely ordering a motor from CCR (thanks for the tip!!! seriously!!!!!!). I'm figuring it will be the quickest, most reliable and cheapest option. How long you guys think a shop could turn this around, an afternoon? I still don't understand how the other obvious symptoms (oil in fluid, fluid in oil, white nasty exhaust, bubbles in reservoir) are missing here and have been missing for the last 6 months. It has run great through all of this and except for start up, still does!!!
