smkn 951
Everything posted by smkn 951
  1. hello everyone, i have a 93 impreza and want to know what bolt on powers i avail out there and who's the best tuner to get it from. i'm not rich so simple diy also helps. i'm mechanically inclined and do from simple oil change to doing engine swaps. but nothing to do with rebuilding. are there any plug and play mods out there for a 93? tia. also the chk eng light comes on upon reaching 15 mph and stays on????????? but if i start it and let it stay there it won't come on. brake fluid and pads are good. again tia
  2. thanks, i found that the ignition switch was at fault. the switch was coming out of the case, so i pushed it in and reclamped the indents to hold it in. thanks you.
  3. you did hit the nail on the head. ignition switch. took the the cover off the ignition. found the switch and it was coming off the case. pushed it in and reclamped the indent and it worked. thanks a lot
  4. hello everyone, i'm new here. i have a 1993 subaru impreza 4dr. right now the car has all these ailments, won't start, no headlights, windows won't roll down. things ive done and checked. 1. battery teste good with a load tester, voltage is at 13+-1 2. starter is getting voltage to the two big nuts. 3. checked all fuses to include inside and outside boxes (2 total boxes) all good visual and multimeter 4. checked continuity on three relays located inside above fuse box all good iaw the diagram 5. rebuilt starter, might have carbon build up but everything is clean 6. all fluid levels are good. 7. also none of the warning lights in the dash works with the ignition on, but the brake light did come on once, but not anymore please help, this car is an overall great car, it's been very realible on long trips, and i have no intension of getting rid of it. no mods, just plain stock. as soon as i paid for the 944t i'll be modding this one tia :-\
  5. another ailment found; disconnected the battery (negative) for 'bout 30 min. reconnected, all dash lights worked but upon turning the ignition on all the lights went out, tried again to start it but light won't come on. please help tia
  6. hello everyone, i'm new here. i have a 1993 subaru impreza 4dr. right now the car has all these ailments, won't start, no headlights, windows won't roll down. things ive done and checked. 1. battery teste good with a load tester, voltage is at 13+-1 2. starter is getting voltage to the two big nuts. 3. checked all fuses to include inside and outside boxes (2 total boxes) all good visual and multimeter 4. checked continuity on three relays located inside above fuse box all good iaw the diagram 5. rebuilt starter, might have carbon build up but everything is clean 6. all fluid levels are good. please help, this car is an overall great car, it's been very realible on long trips, and i have no intension of getting rid of it. no mods, just plain stock. as soon as i paid for the 944t i'll be modding this one tia :banghead:
