saw
Location
ellicott
saw's Achievements
Member (2/11)
10
To get my AC to work, shorted out my AC evaporator switch (rests atop evaporator). As a consequence, even after restoring to original state, my climate controls, power windows, auto seat belt retractors or tach now do not work. Apparently, my screwing around has shorted something out. Any suggestions as to what I can do to correct?
Pretty sure one of my gaskets is shot. Doesn't show any of the classical symptoms - other than occasional overheating - , but have detected carbon monoxide in cooling system. The car has 196K on it, so the only way I can justify repairing it is if I do it myself. I'm soliciting advice from those who have done the job. What am I getting myself into? What are things I should keep an eye out for? What's the worst part of the job? My Haynes manual says to remove the rocker arm assembly before removing the head. Is this necessary?
Have a '91 legacy with 196K on it. Other than a lot of front axle replacements for torn CV joint boots, been a great car. Over the past few months, have had occasional overheating troubles. The first occurrence was after a 2 mile (one way) jaunt to the local store. The car was cold and ran fine to the store. Upon return, however, the temperature guage began to elevate. Because of the short distance back, everything remained under control. An inspection of the radiator overflow bottle showed it to be full. After cooling, transferred liquid back into radiator and allowed system to run & burp with radiator cap off. Everything's been fine for the past month. This past weekend drove the car for ~ 20miles at 65mph. Switched to some back roads, and after about 5 miles, it started to overheat again. Made it to my destination and checked radiator overflow bottle; once again it was full. After about 5 hours, returned to car to find all liquid had been drawn back into radiator. Returned home with no problems. Upon startup, haven't noticed any excessive smoke emanating from the exhaust. Vehicle runs fine. Have noticed some mild clatter coming from the driver side of the motor when under load - typically when first releasing clutch. Don't know if there could be a tie in or not with overheating problem. Checked sparkplugs this afternoon and they all seem to be burning similarly. Looked into radiator overflow reservoir while engine was running, and noticed some bubbling - possible indication of compression leakage? Any comments, advice appreciated. Thanks.
Finally got around to shorting out AC evap. thermoswitch, and, lo and behold, AC now consistently works. Thanks to all who contributed! Picked another switch up at a junk yard and installed. Operates the same as the first! Only works consistently when shorted. Could this switch also be bad, or is there another explanation?
I've been having an intermittent AC problem. When it works, it cools well. The problem is getting it to turn on and then keeping it on. May work for 20 mins. or 5secs and then kick off. When I look through the receiver-drier view window with the AC on, liquid shoots by, pauses briefly, then shoots by again. It's not a continuous stream. Does this sound like a typical freon flow through one of these systems? The mechanic that looked at it pooh poohed this as the cause for the AC's sporadic nature and said the problem was electrical in nature.
Been havin trouble with my AC for the past several years. Operates intermittently. The unit is reluctant to come on in the morning or evening - essentially when its cooler. On a hot summer afternoon, it inevitably fires up and may run for 15mins. before shutting off and becoming intermittent again. I've had it to the shop. The first time the guy put a little freon in (~ 1/2 lb - not bad for a 15yr old car) and - maybe its my imagination - it seemed to work better. Improved performance lasted for about a week. Now back to the same Took it back into the shop again, and this time was told its something electric. The intermittency, apparently, is due to the voltage cutting off to the compressor. The guy wanted $180 to troubeshoot + whatever parts would be necessary. When I look into the receiver drier sight glass, the liguid shoots through, stops very briefly, and then shoots through again. I mentioned this inconsistent freon stream to the AC mechanic, but he dismissed it as the cause. This crate isn't worth shoving a lot of money into, so I'm looking for suggestions. When the AC is on, it operates well. The problem is getting it to come on and then stay on.
Current '91 legacy has 182K miles on it. Unfortunately, ain't going to last forever. Just wondering what kind of gas mileage you guys have been getting with the newest version? Am only interested in the normally aspirated engine (non-turbo). Please include regular and open road mileages as well as transmission type. Thanks.
Just got back from lunch, and once again when trying to enter my car, had to go in through the passenger side; damn driver door lock was jammed again! For a while there, if I turned the key first to the right, and then to the left, the door would unlock. Lately though, doesn't matter which way I turn it; the key doesn't budge and neither does the lock. I'm sure it has to do with the convoluted linkage system subaru used in the locking mechanism for the '91 model year. Some of you guys have had to have experienced this problem. Exactly what do I have to fiddle with to rectify this problem?
I've noticed over the past couple of days that my climate system fan works only when it's set on the number 4 or high position. The first 3 settings, now, do nothing. I assume, from what I've gleaned off the web, that this has something to do with a bad resistor of some type. Where is this resistor located in a '91 Legacy, and any idea of the price? Thanks.
