HooptyGL
About HooptyGL
- Birthday 05/15/1983
Location
Prescott
Occupation
Student
HooptyGL's Achievements
Advanced Member (3/11)
10
Ok, so its a DR 4wd 1985 GL wagon with about 122k on it. I had just merged back onto the highway after filling up and i noticed the throttle was sticking once i got it into fifth gear. Go i give the accelerator pedal a tap....still stuck. So i move into the middle lane on I-10 eastbound, shift into N and low and behold the tach shoots to 8k. I shut the car down - going about 85 mph - and coast into the shade on the sholder. I popped the hood and one bolt/two washers are just sitting there on my maifold. Throttle body is fully extended, a lot of cable is visible, and it is off the tensioner spring. What do you think, snapped throttle cable or just a toast throttle body mechanism? When the car is fired up the tach shoots to 8k. ------ Neal
Colors. what have you owned? What's common?
HooptyGL replied to Ever Victorious's topic in Old Gen.: 80's GL/DL/XT/Loyales...
85 Wagon - RED http://www.ultimatesubaru.org/photos/showphoto.php?photo=9142&sort=1&cat=500&page=1 94 Lego GT Wagon - Midnight Blue <----Stolen 01-01-05 -
lemme guess its got a brown on brown interior....like this one right? http://www.ultimatesubaru.org/photos/showphoto.php?photo=9142&sort=1&cat=500&page=1 i would kill for paint like that.....congratz!!!!!
No more signatures?!?! SIGNATURE POLL
HooptyGL replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i posted a similar thread in off-topic yesterday....maybe the mods will let it in. -
N baby!!!!!! Hola from Mexico....70 degrees and up during the day (on the gulf of california). I'll be sure to check the plugs when i get back to AZ in feburary...thanks for the BETA on location of the 12mm passenger side nut...im sure thats what it is but if not ill be sure to call you up to source me some mounts. Adios from the land of sun and surf.
More often then not if I start up the car in 2WD and then try to switch into 4WD high I get a painfull whirring / grinding / noise from hell when my foot comes off the clutch and the car goes no where. The only way i can get the car to move then is engaging the lever (85's did not have push button) into 4WD low, and holding the lever in place.
I have been doing a bit of firewood collecting in the areas of prescribed burns and need to keep my '85 GL wagon in 4wd high when it gets shut down so that I can get out of the woods with a full load of Juniper. I've begun to notice that the engine is having a bit of trouble firing up when the car is in 4WD. I have never had a problem with start up hesitation in the past. The ea82 engine has a weber 32/36 and is running on 87 octane. The car will fire up fine if it is parked with the car in 2wd. Any ideas on what might be causing this problem? Also...can someone please enlighten me as to the proper method of engaging the car into 4WD LOW. The car does not have a manual to describe how to. Also how can I keep the car from slipping out of low while driving? (without using my right hand to hold it into place) Are there bushings...does the 4WD need to be serviced??? ---- Neal
your rotties are funny looking!
dude.....without those engine spacers the body clearance is increased but the engine sits at the same height in relation to the frame.....why not have the spacers that come with the outback for that very reason?
no in that case you would have an outback. in order for the ob strut swap to be done correctly you need to source a plethora of suspension parts from the doaner outback...like bushings and the FREAKING ENGINE SPACERS THAT GO BETWEEN THE ENGINE AND THE CROSSMEMBER...it is a very common modification to lego's.
pretty sure lego springs on a '95 ob strut adds 2 " to ride height on any legacy through 99...you need the frame spacers though and a few other parts from the donor OB's suspension. i heard from a little birdy that you can re-bore the holes on the strut towers and Forester stuts will slide right on in. that would actually give your OB a bit more clearance....just my $.02 - neal
well that sure would suck to be him...unless he didn't give a flying-hoot about what he had to pay for go juice. oh and i meant to put out a + for OB struts...im pretty sure i used the springs off my lego though... what does your ob lego get with the fuel injection...i cant remember if you said it had a lift, bigger tires and all the weight that comes along with that....i dont ever think my 94 gt ever got 30+ mpg....maybe once probably downhill after the borla headers, catback, and the cone went on did you -greengod86- manage to source the engine spacers?...that was a beeoch to pull and then ghetto rig in there with bolts way too huge and mad washers to compensate. free range..the dude who was constantly crashing the ea models into schit...supposedly has seen forester struts slide into re-drilled slots, but i cant remember if he did that onto his lego or if it was ontosome one elses ea. Mud Rat would know.
