mulletkill
Everything posted by mulletkill
Sorry to bump a 5yr old thread, but I've searched and searched and this is the only guy with similiar symptoms as I'm having right now.. Only exception is I'm pretty sure its not a heat shield. Only heat shields on my car are on my turbocharger, and for the exhaust manifold(headers). I think its something related to the transmission. Appears to be coming close to the front drivers side wheel well.. Things that have crossed my mind but I'm not sold on them: power steering fluid/pump CV joint wheel bearing rubbing on the rotor/brakes
If I had a 4.11 in the front diff with a 4.444 rear, how obvious would it be during normal driving? Just had a new tranny put on my 04 Forester XT Auto last week, trying to eliminate this as my problem. Wouldn't I be getting lots of binding and bucking? If I'm understanding it correctly, the rear driveshaft would be spinning faster than the front one right? The XT's have the Active AWD(90F/10R controlled by a transfer clutch) but on "power brake" launches to 3,000rpms with my high stall torque converter, the rears just spin and spin, even fishtailed..Even on a semi-normal takeoff from a redlight on a wet road, I fishtailed. Fluids in both diffs were drained/refilled last week along with new ATF put in when the tranny was swapped. Am I just being paranoid? Discuss.
I just had my rear left wheel bearing replaced 3 weeks ago...Have only put about 400 miles on it since..It just quiet til about 2 days ago when I noticed grinding noise again...(on right turns). Then today heard some grinding from that wheel on a left turn..Could the bearing be toast already, or is it possible an axle nut or lateral link bolt was over/under torqued? any ideas? This was the first bearing to go on my car...Its a 99 Outback SUS, 78k.
