bratsrus1
bratsrus1 last won the day on April 9 2017
bratsrus1 had the most liked content!
1 Follower
About bratsrus1
  • Birthday 05/05/1956
Contact Methods
  • Website URL
    http://
  • Location
    Selah Washington
  • Interests
    cars and more cars
  • Occupation
    case service tech
  • Ezboard Name
    bratsrus1
  • Biography
    cars and more cars
  • Vehicles
    1980 hatchbrat
Recent Profile Visitors
bratsrus1's Achievements
Subaru Nut
Subaru Nut (7/11)
58
  1. Hello, i was reading through some posts and came across your name.  I am in the situation where my 84 GL wagon 4speed manual d/r is going out. 3rd gear is already gone and 4th and Reverse are grinding now.  It seems that swapping in the EA82 5 speed is the way to go.  What would the best way to go about this be with minimal custom fabrication. i don't have access to welders or torches, just normal shade tree mechanic tool. Thanks a million for your help.
  2. Hi Paul This is Jerry, yes i hope you can make the subie show you will be hook on it. There has been 19 shows i have made 18 of them hope to see you buddy. Thanks Jerry
  3. Hi This is Jerry, give me a call i am the guy that makes the 5 speed kit for the EA81 cars. 509-952-2855 Thanks Jerry
  4. Hi This is Jerry, my wife is putting together a scrap book of the show she needs pictures of the cars that was at the show. Please email them to 2005 baja@ gmail. com Thanks Jerry
  5. Hi This is Jerry, i have a 95 impreza GC8 and i want to remove the front grill i don't see any bolts to remove to get the grill off. Can somebody that has done this please let me know how to get it off, i don't want to brake it. Why the grill off i want to install my hella horns. Thanks Jerry
  6. Hi This is Jerry i live in Selah WA. and there is a place in Yakima called drive line services there # 509-452-3095 or 4526403 they have no problem doing your drive line. Thanks Jerry
  7. Hi This is Jerry, i make a 5 speed kit for the EA81 cars give me a call 509-952-2855. Thanks Jerry
  8. Hi This is Jerry, yes it can be done i did it on a 86 hatch back. The sami frame fits to the subie frame, i had to lengthen the sami frame 13 inches to fit the wheel wells on the subie. I built a car turnner and flip the subie upside down so gravity was my friend. I put the sami frame on top of the subie and started to make my frame mounts. I used the sami front and rear axles and the transfer case, the engine is 2.2 with the 5 speed dual range trans. I also went spring over on the axles, my avatar shows that project. Thanks Jerry
  9. Hi This is Jerry, i make a 5 speed kit to fit your brat call me i can let you know all about it 509-952-2855. Thanks Jerry
  10. Hi This is Jerry, the 4 speeds suck compare to the 5 speed trans find a 5 speed dual range trans bolts in. Want to know more call me 509-952-2855 Thanks Jerry
  11. Hi This is Jerry, i make a 5 speed swap kit to fit the EA81 cars call me 509-952-2855 Thanks Jerry
  12. Hi This is Jerry, i make a 5 speed kit for your car and it retains all the stock shifters a consel everything is still stock inside of your car. With this you unbolt the old and bolt in the new, want to know more call me 509-952-2855 Thanks Jerry
  13. Hi This is Jerry, yes i will be there time to put in for vacation. Thanks Jerery
  14. Hi This is Jerry, i have everything you need i have the bolt, the spring, the ball and the case half. Let me know we can make a deal 509-952-2855. Thanks Jerry
  15. Hi This is Jerry, yes you can up grade with the 5 speed dual range trans. i am the guy that makes the kit to do this swap over call me and i will tell you all about it. 509-952-2855 Thanks Jerry
