Everything posted by bratsrus1
Hi This is Jerry, if your brat has an EA81 with a 4 speed i have motor mounts and tranny mounts. Let me know we can strike up a deal. Thanks Jerry
Studs.. or rip them out...
bratsrus1 replied to Indrid cold's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hey Mike This is Jerry, put the wheels on your hatch and drive. When spring gets here just get a small blade screw driver and pop the studs out. Your are ready to go, done this many of times. Once you pull the studs you can't install new ones. Thanks Jerry -
Hey Marty This is Jerry, your brumby is really cool only one thing you can improve with it. Thats to install a 5 speed dual range tranny. I make a kit for your brumby i think if it's the same as our brats in the states then it will fit. With this kit all of your shifters and consel remain stock. If you are interested in a kit let me know. I have ship some parts to Aussie before. Thanks Jerry
Hey Big Guy This is Jerry, well stuff the sammy frame and running gear under the brat and go spring over. Then you use the 2.2 EJ engine with the 5 speed dual range tranny mated up to the sammy T case then you got some low gears. The sammy is the same width as the subaru, you will have to lengthen the sammy frame to fit the subie wheel base a really fun project. Thanks Jerry
Nitrous and Turbo EA81T EA82T
bratsrus1 replied to Myxalplyx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hi This is Jerry, well i have seen an XT turbo with nitrus on it. The car took first place in tuff truck 2 years in a row then he got band from running it. The first time the guy hit the button everybody though he blew it up smoke every where. He blew all the smog stuff off of the engine to much crank case pressure. So yeah it can be done:lol: Thanks Jerry -
05 Baja
bratsrus1 replied to bratsrus1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Hi This is Jerry, yes the Baja is my wifes pickup and i tell everybody the EA81 cars are a blast to drive and the Baja is class to drive. Thanks Jerry -
05 Baja
Hi This is Jerry, the Baja is my wifes subie. You ask do what well to post more pictures, i hope i can remember how to do it. Thanks Jerry -
I Got My Hatch Wooooooh!!!!
bratsrus1 replied to subaruguru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hi This is Jerry, if you click on my photos you will see my daily driver. It is the maroon 86 hatch well Robby got the twin to it. Yes it needs some work but when we are done with it cool beans a good daily driver. Thanks Jerry -
Hey Brian This is Jerry, yes the 5 speed is way bigger it will not fit in that small tunnel. The best way to do that project is to get a tunnel from a EA81 or EA82 car cut the entire tunnel out and set it inside of the early car mark it then cut the small tunnel out and weld the bigger in that way all the shift linkage will work. The tranny mounts will have to be custom made. Good luck Thanks Jerry
Hi This is Jerry, well not putting the engine back together yet because i got the heads all clean up and i found a bent valve one in each head. Well it's valve job time, the way i found this out was to spray brake clean into the intake runners. All the valve are closed and brake clean ran out of one of the intake vales it's bent, one on each head. Life gose on i will get this engine running with the holley 4 barrel carb on it. Thanks Jerry
Hi This is Jerry, yes the engine is out of the car. The reason i am removing the heads is because the engine had something in it. It would turn about 320 degrees then stop i could turn it back the same amonut something was in the engine. The engine is a 96 imperza 2.2 zero carlance engine also this engine was in a front end crash. Well i got it apart and i started to laugh it had to much carbin in it, the crash jared it loose. The o2 sensor must have been bad i have seen less carbin on a carb engine. Now time to put it back together. Thanks Jerry
Hi This is Jerry, the control unit is located on the right front inner fender. It is a black box about 2 inch square and is held on with one sheet metal screw. Thanks Jerry
Hey Soob This is Jerry, i have 3 of those mounts come on down and you can have them for FREE. I live in Selah next to Yakima let me know Thanks Jerry
Strut rods (was Strut bars)
bratsrus1 replied to Hodaka Rider's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hey Rider This is Jerry, yes i had them on my 86 brat. My brat use to pull to the left and i took it to the tire shop. They told me my left wheel was not inline with the right wheel. So they told me i needed those adjustable strut rods, they install them and moved the left wheel to line up the right wheel no more pull fix the problem. Thanks Jerry -
Hey Subie This is Jerry, if the antenna is on the left side then all you need to do is pull back the inner fender and you can get at it. If it is on the right fender weel then you will need to remove the fender not unless you have 12 inch fingers to reach the antenna nut inside of the fender. Thanks Jerry
Hey Bush This is Jerry, i will not drive any else but a subaru. When winter hits the only car i will drive, i have a 86 hatch my daily driver. I got it about 3 years ago and i got 85 thousand miles it no trouble. Tomorrow morning i will get in my hatch turn the key and away we go another 100 mile day. Ask me if i like my subie well yeah i have 3 of them and my wife has a 05 baja. Thanks Jerry
Hey Dave This is Jerry, just to let you know the wiring diagram is in the mail. Thanks Jerry
Finaaly got the Brat Engine Home
bratsrus1 replied to newsoobdude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hey dude This is Jerry, if you are going to have the cam reground then you will have to split the case. Make sure you know how to time the engine before you slpit it. Because when you read how to time it you are going to say what the h**l are they talking about. And then you already have it split hone the cylinders and rering it. Thanks Jerry -
Hi Dave This is Jerry, i have a 82 FSM and i can photo copy it for you but i can't mail it until monday. My wife had sholder surgery today and i am the butler until monday morning so if you can hold out until monday i can do this for you. Let me know Thanks Jerry
Hi This is Jerry, i have a 86 and a 80 hatch bolth of them have trailer hitches on them. I built them and i didn't install different shocks everything works fine. What i did was fine in the wrecking yard a class 1 hitch and cut it all up useing just the center part of the hitch only. Then i built everything else to fit the hatch. Thanks Jerry
Hi This is Jerry, i have a set of tranny mounts for your 4 speed make me an offer. But the best thing to do is what GD said install a 5 speed into your brat you will love it. Thanks Jerry
New for me, 84 Hatch..
Hi This is Jerry, i have axles for your car cheap come on up and see me. I have other stuff for it also call me 952-2855 Thanks Jerry -
Hi This is Jerry, i live in Selah i can look at it if you want me to. Let me know call me 952-2855 Thanks Jerry
