bratsrus1
Everything posted by bratsrus1
  1. Hi Kim This is Jerry, if you get that crank from me you will get the rods with it, just to let you know. Thanks Jerry
  2. Hi Everybody This is Jerry, yes Amanda is right on that only miss show #2 thats it. You betcha i will be there this is the place i get to talk to everybody in person and see everybodys subies that they have been building all year. I was at show 3 really cool place lots of things to do, so if anybody is thinking maybe or maybe not this is a must be show to go to. Thanks Jerry
  3. Hi This is Jerry, i have that cable that you need make me an offer on it. Thanks Jerry
  4. bratsrus1
    hehehe
    Hey Austin This is Jerry, come on down just let me know when you are going to be here so i will be home not out wrecking hopping. Thanks Jerry
  5. Hey Paul This is Jerry, now that spring is here where i live i have my cragars back on my hatch wow you said it the looks people give me. You can read there faces that little car makes that kind of sound. I have had people talk to me and ask if it has a V8 in it. yes it has and it was a *************** to get it in there then i open up the hood and say it's all about gas mileage and smile. Thanks Jerry
  6. Hi 86 This is Jerry, yes i have a lathe and it takes alot of time. Balance is not the problem if you get everything centered it's got to be centered or it will like driving on a wash board road. Thanks Jerry
  7. Hi This is Jerry, i redrilled my hubs on 86 hatch over 4 years ago. The bolt patteren is 4 on 4 1/2 toytoa i have mini cragars on it really cool. I also turn down the outside of the hub less weight. Look at my photos and you will see my car with the cragars on it. Thanks Jerry
  8. bratsrus1
    hehehe
    Hi Everybody This is Jerry, with this hatchbrat i will have to jump to get into it or jump on the nurff bar to get into it. I can't lift my foot that high Thanks Jerry
  9. Hi Everybody This is Jerry, if you click on my photos you will see this sammy frame. Went out in the wind and took some pictures of my subies. Thanks Jerry
  10. bratsrus1
    hehehe
    Hi Everybody This is Jerry, if you click on my photos you will see the frame of this sammy. Thanks Jerry
  11. Hi Jibs This is Jerry, the hardest part about doing this project so far was making the frame that i was able to turn the car upside down on its roof. I had gravity on my side it held the frame in one spot so i could line everything up. The steering is all sammy, come to the show this year and see it. Thanks Jerry
  12. bratsrus1
    hehehe
    Hey Uberoo This is Jerry, there is no lift on the body just a spring over the axle. The frame from the sammy is inside of the subie unibody frame. The inside of the subie frame is 28 1/2 wide and the sammy frame outside width is 28 inches wide it fits inside of the subie frame. Thanks Jerry
  13. Hi Del This is Jerry, yes you can see it in person call me 952-2855. I an using subie 2.2 with the 5 speed dual range tranny and sammy front end and rear end and T case all sammy. Thanks Jerry
  14. bratsrus1
    hehehe
    Hey Uberoo This is Jerry, there is no lift. What i did is mount a sammy frame to the hatch body and did a spring over the axle. The sammy frame fits inside of the subie frame and follows it. All i can say come to the show this year and see it. Thanks Jerry
  15. Hey 75 This is Jerry, yes those are sammy axles also has a sammy frame under it. I had to lenghten the frame 13 inches. The manifold is a 2.2 that will have a holley 390 cfm on it old school baby i like it. The roof is from a 82 GL brat yes Tee Tops and the back wall is also welded into it. Thanks Jerry
  16. bratsrus1
    hehehe
    Hi Eric This is Jerry, i know about the tires it's the wheels that i was looking for. You really can't see the tape but it's at 41 inches and will be taller with bigger tires. Thanks Jerry
  17. bratsrus1
    hehehe
    whatcha think? thanks, jerry
  18. whats that? how tall is tall?:headbang:whatcha think?thanks, jerry
  19. Hey Brian This is Jerry, when you come over to my house i have the wiring for that dissy it's a simple hook up. Thanks Jerry
  20. Hi Frank This is Jerry, there is a seperate fuse on the EA81 cars for the blower motor that is under the steering column. It is a fuse all by itself and it is a round white holder that uses a round glass fuse. Alot of people don't know about this fuse, i found it on my hatch by looking in the repair manual. Thanks Jerry
  21. Hi Connie This is Jerry, there is a guy that has the same car that you have and he had a problem with the charging system. The problem he had was the crank pulley. It was spinning inside of its self where the inside of the pulley was turning engine speed but the out side of the pulley was spinning about half speed. Please look at that you could have the same problem. Thanks Jerry
  22. Hi This is Jerry, yes you do need that part. That part catches the oil splash and lubs the input shaft bearing. If you don't install that part your tranny will be short lived. Thanks Jerry
  23. Hi This is Jerry, forget the 4 speed and install a 5 speed you have to make brackets any ways. I used some 1 1/2 inch angle iron and welded it to the EA71 cross member and drill holes where i needed them to be for the 5 speed mounts. Then cut the shift linkage to fit, 5 speed is installed. Thanks Jerry
  24. Hey Zack This is Jerry, you can do what i done on my hatch. I put a different bolt patteren in the hubs and it is 4 on 4 1/2 and that is toyota car. I have a set of cragars on my hatch and alot of people see it and say where did you find those wheels to fit your car. I smile and say they are a toyota car bolt patteren. Thanks Jerry
  25. Hi This is Jerry, been there done that on an 81 brat. I built a 6 inch lift for it i also installed a EA81 with a 5 speed dual range tranny. The rear i use the 84 brat rear end because it was alot ez er to install with the 6 inch lift. Aslo rear disc brakes is a must have. Thanks Jerry
