bratsrus1
Everything posted by bratsrus1
  1. Hi Everybody This is Jerry, i was looking at the Wcss7 show pictures and i have to thank all the people that took pictures of my hatch back. For those people that haven't seen my old school hach you can find it on the link of Wcss7 pictures and look for subarujunkies post. Click on the pictures and you will see album of Jibs thats it the maroon hatch with the cragars and side pipes now thats old school. What do you think of it? Thanks Jerry BTW Thanks to ALL the people that took the pictures.
  2. Hey Blue84 This is Jerry, i am doing that project also. Remove bolth dissy gears and drill another hole in the EA81 gear to match the hole in the EA82 gear. After that is done install the EA81 gear on the EA82 dissy. That is how you do that fix. Thanks Jerry
  3. Hi subieguy This is Jerry, yes they still make that filter. The part# is SOA5165100 it is the same as the EA81 engines. Thanks Jerry
  4. Hi Glenn This is Jerry, the size for your roll pins is 7/32 a good tool store or snap on will have it. Thanks Jerry
  5. Hey Beegeer This is Jerry, if you have the 8 and 7/8 clutch on your subie now then all you need is the clutch disc the disc comes from the 86 5 speed it has a round center hub with 6 springs in it that will fit your EA81 flywheel and pressure plate. You don't need the EA82 flywheel. If you have the small flywheel then find you the large one, if you have any more questions call me 1-509-952-2855 Thanks Jerry
  6. Hey Bobby This is Jerry, i live in Selah but i drive to sunnyside everyday to go to work. Stop in at lunch hour 12:00 and we can look at each others subarus. Let me know what day so i will be there. Thanks Jerry
  7. Hey Dayn This is Jerry,come to the show and you will see one of the best ways to do your exhaust. I have it on my 86 hatch back, well all i can say it is true dual exhaust. See you at the show. Thanks Jerry
  8. Hi This is Jerry, yes sir ree i will be there with my old school hatch. Now everybody is saying old school come to the show and you will see it cool. Thanks Jerry
  9. Hi Clay This is Jerry, yes i am serious about having the oil pump. If you need any thing else let me know. I am getting the SPFI complete and wiring harrness everything is up for grabs. Thanks Jerry
  10. Hey Clay This is Jerry, if your car is an Ea82 with SPFI i have a car that i can give you the oil pump from it. The car is a 86 3 door, let me know Thanks Jerry
  11. Hey Caboobaroo This is jerry, is your Rx body style like the 86 three door? If it is i have the glass just got to let me know how to remove it. Let me know Thanks Jerry
  12. Hi This is Jerry, i PM you yesterday about the 5 speed in my hatch did you read it. I have over 35,000 miles on my 5 speed in my hatch i love it. I use my hatch as a road runner and i have the turbo 5 speed dual range tranny with 3.70 gears. Not any good off road but the freeway works really good. Want to know more let me know Thanks Jerry
  13. Hey Isaac This is Jerry, i just got a Ea71 from a 80 brat yesterday that runs really good. I want to sell it for 100.00 without the carb. Come and get it and you can have the tranny also, i live in Selah Washington. Make a day trip out of it, let me know. Thanks Jerry
  14. Hey Captain This is Jerry, i have the set up you need to do this swap over. I have a 86 hatch that has a EA81 with the 5 speed front wheel drive. The car has the Ea81 engine with the Ea71 bellhousing that will bolt up to your tranny. I am removing the engine and tranny in about 2 weeks, that stuff will be for sale or trade. Let me know if you are interested in it. Thanks Jerry
  15. Hey Zefy This is Jerry,i call BS on that one because i have a EA81 with a 5 speed front wheel drive 86 hatch that has that bellhousing. It will be up for sale when i part the car out soon. Thanks Jerry
  16. Hi This is Jerry, yes i have done this on my hatch. The bolt pattern i have is 4 on 4 1/2 and that is mustang 2 or toyota. I will have my car at the show so everybody can see it. I am also drilling another set of hubs to 4 on 4/3 to fit a set of stotted mags that i have. Thanks Jerry
  17. Hi Mary This is Jerry, it sounds like it's the carb. You have a vacuum leak inside of the carb. thats why it stays running in the winter. The choke is on , it makes the carb run richer. Install a weber and it should run fine. I have a small weber that came off of a Fiat and the size is a 2c-30DICA1. That would be purfect for your EA71 engine. It has a manual choke and needs a carb kit. I have the adapture for the fiat but i don't think it will fit your brat. Have to have somebody make the adapture. Let me know if your interested in it. Thanks Jerry
  18. Hey Subyrally This is Jerry, well cooper makes that tire size. It is called cooper cobra P205/60TR13 part # 39603. Check with your tire dealer and see if he can get them. Thanks Jerry
  19. Hey Jibs This is Jerry, the EA81 cars will fit but the EA82 cars won't fit they are to long. Yes get another trailing arm from a EA81 car and at the same time get the rear disc off of the EA82 and do the swap. Thanks Jerry
  20. Hi This is Jerry, if this is a gen 1 brat well then you need to look under the glove box. There is 2 or 3 fuses there and 1 of them is the charging light power. It is a 5 amp fuse, i found it by luck. Hopes this helps you. Thanks Jerry
  21. Hi This is Jerry, the parts book has the #7910 17130 and the screw part # 0460 04144. Hpoe this is what you are looking for. Thanks Jerry
  22. Hi Bill This is Jerry,the rattle is from the antie rattle bushing that is wore out. That bushing is under the shifter, to get to it you need to remove the consel. Then remove the rubber boot under the consel, then go under the car and remover the 2 nuts that holdes the shifter to the linkage. You will find a black piece of rubber around the white half ball that is on the end of the shifter. That black piece of rubber is it, go to dealer and get a new one part # 33154GA210 it cost about 3 bucks. When you put this back together make sure you put some grease on the ball. Thanks Jerry
  23. Hi This is Jerry, yes you can do that but you need a donor car to get all the parts alot cheaper that way. Thanks Jerry
  24. Hi This is Jerry, everybody is asking for these things for the outside of there cars. Well the bestest thing any body can come up with is a set of gears for the 5 speed dual range tranny 4.44 Come on everybody say yes that would be a great idea, i can't hear you say YES. Oh BTW i am first in line to buy these gears. Thanks Jerry
  25. Hey Pooparu This is Jerry, call me i can tell you all about the swap. My # 1-509-952-2855 Thanks Jerry
