Search the Community
Showing results for tags '#legacy'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. 1999 Subaru Legacy 30th anniversary edition 5 speed MT ej22 Car starts, runs for a few seconds, then dies, will not idle. With proper TPS adjustments car runs without MAF connected, but dies as soon as it's plugged in. Car ran perfectly healthy until I replaced coolant temp sensor, tried putting old sensor back in, did not help. Tried pumping gas while starting car, caused motor to sputter,buck and die. Whats new: MAF (has been replaced three times over the course of two weeks) TPS PCV valve Hoses that connect to the PCV from the torque box Battery Thermostat Coolant temp sensor What's been tested: Fuel pressure within spec gets spark gets fuel All sensors have been back tasted and are receiving and putting out the proper amount of electricity. Smoke tested for vacuum leaks (there were none) I have absolutely no idea what could be wrong, after the extensive amounts of diagnosis I'm at a standstill. Any suggestions would be appreciated.
