Search the Community
Showing results for tags '06 legacy'.
Hello, I have a Legacy and when I release the trunk, I hear only a click (latch release) the trunk will not raise by itself from that position. I have purchased New Subaru Trunk Torsion Bars for it and going to put them on, but I need to know the correct positioning of the contact between the Torsion Bar and the Swivel Lever it attaches to. The the Bend in the Torsion Bar Correct (Like attached Image) or the other way? On my car now the bend is in the same position. The guy at Subaru said there is a Driver Side(L) and Passenger® does the one that is driver mean that the s part goes in the driver side or the part that presses on the lifting portion I hope this makes sense Thanks for any help you can give.
Hello, I was wondering if there is a correct procedure or way to ensure both the Block and Head are correctly aligned to put on the timing belt. At this time the heads are on and not tension on any of the Valve Rockers. The pistons are all in the Neutral Position (all in as far as they will go) The crank gear is aligned with Crank sensor, so I am sure it is off some degree? Thanks for any help
- 4 replies
- 06 legacy
- Timing Belt Procedure 2.5i
(and 1 more)
Tagged with:
Hello, I'm most likely going to install Bilstein B6 Shocks & Struts on my Legacy. I know I need the B-Spec Front Strut Mount. I noticed on Tirerack that they say it may increase the ride height of the car, but they don't say how much. Has anyone ever installed these? Do you have an image with these on it? Any issues with Bilstein? The KYB that are on the back are very soft and bouncy.. Thoughts? Images?
