Search the Community
Showing results for tags '1.8L timing belt'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Car wouldn't start after parking it for a 1/2 hour on a slight hill. Had it towed home. I determined the timing belt had failed by removing the right cover and placing a mark on the belt...started the engine and it did not move. Took it apart, lined up my marks but forgot about the #1 cylinder thing~ redid it...using a gun cleaning rod dropped down into cylinger #1 and putting a mark on it in line with the edge of the body to detect the upstroke. When it was out the farthest, the arrow on the crank sprocket was right where it should be. I cranked the right hand side clockwise to bring the mark up. The left cam pulley is freed. I positioned the belt using all the marks, installed the tensioner and bottom pulley, pulled the pin and nothing moved out of position. I put the crank pulley and bolt back on...(runs better with it on) and it wouldn't start. Is it possible that even though it seemed cylinder 1 piston was all the way up that it was actually up on the exhaust stroke? Am I not understanding this? Also, I think I need to clear some codes, because I questioned that the MAF may have failed too...and I remembered I had another Subaru that would run with the (bad) MAF sensor unplugged. It wouldn't run well, but it ran. In unplugging it, maybe I threw up some codes, and because the car is so old, I don't think there is a port to plug in my diagnostic tool. Could it be the crank sensor? Car aaaaaaaaaaaalmost wants to fire. I changed the filter as I hadn't since I got the car. Key on, fuel shoots out. This is my third timing belt change and I can't help but think there may be something else wrong.
