Search the Community
Showing results for tags '1983 Brat'.
So I'm in the process of revamping my exhaust. I've taken the ASV brackets off of the exhaust manifold, and I'm going to extend my Y-pipes up to the engine itself without the brackets. I took the old crusty gaskets out, and I'm buying new ones. But all of the gaskets that it seems I can order are just simple rings, whereas the ones that I took off were the shape of the pipe flanges on my Y-pipes. My engine is an EA81 on my '83 BRAT. What kind of gaskets do you guys have at this spot? Will the simple, circular ones work? My whole point of working on the exhaust in the first place was to keep it from leaking right at this spot, so I want something that will hold well.
- 21 replies
For the EA81 engine, and 1983 Brat, does anyone know where the Engine Coolant Temperature (ECT) sensor is? There is a sensor near the thermostat housing (which is by where the upper radiator hose connects to the intake manifold I think, passenger side of engine bay) but this sensor is two-pronged which means that, according to all parts catalogs that I've looked at, it is the radiator fan switch, not the temp. sensor that connects with the dashboard temp. gauge. The temperature sensor is just one pronged (at least the aftermarkets that you can buy are one pronged).
- 8 replies
- Temperature Sensor
- EA81
(and 6 more)
Tagged with:
I'm getting sick of the garbage aftermarket carpet that I bought a long time ago--it doesn't even fit because it isn't wide enough. So I want to just clean the heck out of my floor and coat with some sort of durable finish and then get rubber mats. With that said, I have two questions: What would be good to clean the floor with? (something strong enough to get the remnants of the old carpet with its adhesive and all) I don't want to coat it with just rhino liner type stuff on the inside, but I want something that is similar. I just don't want something that's so rough, something that will be easier to clean since it'll be on the interior. Is there something similar to bed liner that is smoother? (Or something that you guys know about that will suit my purposes better)
So I have a 1983 Brat that I have had a ton of work done on. It finally doesn't leak oil and it runs great. The EA81 in it only has a little over 150,000 miles on it, but all of the ports that have anything to do with the ERG system (or any other emissions control system) have been plugged with bolts and welded shut. The previous owner did all of that. I don't know if that has any relevance, but anytime the windows are down you can smell exhaust (at least I think it's exhaust) really really strongly. I can be going 70-80 mph on the freeway, but if the windows are down I can still smell exhaust. What could be causing this? Surely, although it is an old car, not all old cars smelled like this. Is there an exhaust leak somewhere between the outtake and the muffler?
Here are the pics showing how my EGR/ASV system was plugged/modified, whatever you want to call it. First is a picture of the entire engine. Look below to where the exhaust would come out. There is a little pipe about the size of a quarter in diameter coming towards the camera, it's been cut and welded shut. The next picture is of the same pipe, just on the other side of the engine, the driver side. Same thing. I was told these pipes are part of the ASV system by someone on a forum here. My mechanic said EGR.. Wouldn't these pipes normally lead up to the EGR valve somehow so it can redirect exhaust to the intake? On the first pic, see the bolt directly above the pipe I'm talking about. What engine port is this. There is just a bolt instead whatever went here. A sensor perhaps? The third picture is a closer image of this same bolt/port. It is right by the passenger-side rear spark plug. The next (fourth) picture shows the EGR valve close up. As you can see, the (intake?) hose for the valve just has a bolt shoved in it. The fifth picture is just a view from a little farther away so you can see where the valve is.. The sixth pic is of the EGR valve, looking from the passenger side. This shows another engine port on the intake manifold where a bolt has just been shoved in. What is this port for?? The horrible part is that I don't know if these "bolts" can be easily removed. They look like they were welded in.. One last question, the last (seventh) pic shows the passenger side of the engine from the front view. There are tons of attachment points for bolts and what not on this side. What are they meant for?
- 4 replies
- picspictures
- brat
(and 5 more)
Tagged with:
So my Brat has always had pretty weak headlights, but lately they have been downright unreliable. My car runs completely fine, but when I go to turn the lights on at night, my headlights flicker off. When they turn off, I also hear a strange electrical sound (sounds like a servo or something like that). It doesn't happen every single time that I try to run my headlights, but pretty close. I don't think it's the battery, and I already took my alternator out and had it tested, but it passed the test just fine at O'Reilly's. Could it only be bad wiring that is doing this, or does anybody have any other ideas of what the problem might be? p.s. The right headlight shines weaker than the left. I don't know if that is significant or not.
- 29 replies
Does anybody know if the 32/36 DGEV model Carburetor from Weber Carbs is the only model that would be compatible with the EA81 engine? Also, are weber carbs recommended? What do you all think?
- 7 replies
- Weber Carburetor
- EA81
(and 3 more)
Tagged with:
