Search the Community
Showing results for tags '1987 gl'.
Somewhere along the road from Alaska to Utah one of the boots of my front right CV axle blew a hole and I still haven't dealt with it properly, the axle is getting pretty noisy now. I browsed the forums here pretty thoroughly and compared what I read to the FSM Diagrams, then pulled the trigger on this axle from Rockauto which they have listed as fitting a front right 4wd MT Fuel Injected 1987 GL with my SOHC engine. After getting the axle in the mail today though I counted the splines and realized it has 25, not the 23 the manual says I'll need. So I'm wondering if anyone else has experience with this so I can know whether or not the axle will fit before I tear the car apart and count the splines on the old one?
Hi all! Im sort of new to this whole thing but here it goes, I have a 1987 subaru gl base with the stock EA82 engine in it. Im 16 and I certainly dont know all that much about cars so Im not sure what could be going on but ill try to explain, I had removed the battery and when I went to put it back in I placed the positive wire to the positive terminal and the black box thats mounted to the coolant tank popped and start to smoke. All three wires that were in it blew in half and now when I go to start it nothing happens. The battery was in correctly im not that naive but im not sure what I need to do. Any suggestions?
