Search the Community
Showing results for tags '1990 legacy'.
Brought my son's 1990 Legacy L Wagon to local mechanic because it's been running rough (hard starting, strange idling, stall at red light, etc.) The shop having trouble reading and deciphering all info given by computer because they don't work on vehicles this old often. They thought they narrowed d...
- 4 replies
- 1990 Legacy
- mechanic
(and 1 more)
Tagged with:
Hello everybody! Just a little background on my situation. I stumbled across a 1990 legacy for 600 bucks. Guy said he put in new tranny and had the engine out to replace seals and gaskets. Well 380 miles into my trip I stop and find I've lost 3 quarts of oil. Holy cow! Get home and see the oil pan a...
My 1990 legacy didnt idle for about a week so i replaced the MAFS, cleaned the throttle body, cleaned the air intake valve, replaced the PCV valve, replaced the PCV hose to the air intake. After all that she finally idles but its really rough it bounces from 0- about 1000 rpm is there any reason it...
- 1 reply
- rough idle
- 1990 legacy
(and 1 more)
Tagged with:
I have a 1990 subaru legacy manual Trans and I've been having quite the idling issue. I just replaced the MAFS and she still won't idle what so ever. I'm planning on cleaning my throttle body and replacing the gasket to see if that helps. I've already replaced the top end throttle body vacuum line a...
- 4 replies
- 1990 legacy no idle
- 1990 legacy
(and 5 more)
Tagged with:
Hi all, new to the forum and in dire need of help. None of my power windows are operable and I can't find a wiring diagram. It's a 1990 Legacy wagon and I can't locate a power window fuse position. But wait, it gets better! The A/C is also inoperable. And....I have a broken right hand and the onl...
Hey All, I am in need of some help from someone who knows their way around an older Subaru. I purchased a 1990 Subaru Legacy Wagon with only 86k miles on it from a single owner. The car is in great shape and I felt was an excellent buy. After putting a few thousand miles on it Ive noticed that...
- 26 replies
- 1990 legacy
- wagon
(and 1 more)
Tagged with:
