Search the Community
Showing results for tags '1990 loyale'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 4 results
  1. I have a 1990 Subaru loyale with a no start no spark I’ve replaced ignition distributor made sure it is properly wired the only thing is the ignition pulse if I’ve done the test right with a test light. there is no pulse. There is also other random stuff that doesn’t work on the car , lights, dash light etc. I wondering if it is infact the ecu that isn’t working and if not other things it would be side note there is no check engine light or codes
  2. I have a 1990 Loyale, 300k miles, beater but generally reliable car. Its been running hot from time to time, but yesterday was running close to the red on temp gauge. Added coolant, but noted there is a leak coming from the plastic nut located just above the drain stop cock. Pulled that leaky nut out and found the threads and washer are shot. Can anyone tell me the purpose of that aperture into the radiator? Can I just replace that or plug it with a similar nut, or do I need a specialized part? Alos note the fan is not working. How can I tell where the fan faiure lies? Fan Motor? Controll Unit? Thermostat?
  3. Hello All, My son's 1990 Loyale with an EZ82 non-turbo manual transmission, intermittently races to 3500 RPM or so. Just started. Any Ideas?
  4. Hello All, My son's 1990 Loyale with an EZ82 non-turbo manual transmission, intermittently races to 3500 RPM or so. Just started. Any Ideas?
