Search the Community
Showing results for tags '1991 subaru legacy'.
I have a 1991 Legacy with code 24 and it would not fire on cylinder one as per the usual in limp mode with said code. I replaced the tps and now it fires on all 4 and it's a new pre-calibrated IACV. Is it possible calibration is off? All the wires have been rebuilt/replaced that got to the iacv. I put in a new ecu and it runs a tad smoother now at least. Symptoms: -Cold engine must be revved to about 1.5 to 2k for a few seconds so it's a tiny bit warm to run decently enough. Warm engine is fine. -Idle is higher than it usually is. -Automatic Tranny; Shifts to soon and makes it bog and struggle to speed up -Overdrive engages and stays engaged until under 40 mph which it never did before. [Symptoms are the same across both ecu's except the old onw just made the idle a tad rougher.]
- 4 replies
- 1991 subaru legacy
- iacv
(and 1 more)
Tagged with:
I recently replaced an idle air control valve and the check engine light is still on and the idle is still rough. Do I need to reset the ecu? Or do I have a faulty wire? I'm a bit unsure because normally I've never had to reset the ecu.
- 11 replies
- 1
- Check Engine Light
- Idle Issue
- (and 3 more)
