Search the Community
Showing results for tags '1995 legacy'.
  • Search By Tags
    • 1995 legacy ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 5 results
  1. The gauge stays in the middle when the car is on.Even when only the ignition is on, it goes to the middle. Then back down when the car is off.Goes straight to the middle on a cold start, and stays there when warm and never moves (until I turn off the engine).I unplugged the coolant temp sensor (CTS)...
  2. What I supposed to be a relatively easy task has once again morphed into a nightmare. I bought kyb's 334164 (right) and 334165 (left). They did not come with a "bump stopper". It appears these 2 units are identical except for the brake line hose support location. I also supposed that "right" (3...
  3. Hello. I'm new here making my first post I just bought a 1995 Legacy to replace my 2000 Outback that's having head gasket issues for the third time in three years. Anyway, the new one has some issues that I was curious about. First, it needs a new alternator. Can I use the one that's in the Out...
  4. I have owned a 1995 Subaru Legacy for 5 years but my son has driven it the whole time. It has 165,000 miles on it. WOW
  5. My son is so busy he has no time to answer questions, so I am turning to the forum. I do some work on my own Legacy, but this is a friends 1995 Legacy runs great uphill but bogs down on the flats. 193,000. miles, new plugs, gas filter, air filter. I am thinking it is the fuel pump just want to conf...
