Search the Community
Showing results for tags '1999 impreza outback sport'.
I am having some trouble with my 1999 Subaru Impreza Outback Sport. I was out driving the other day, simple point-a to point-b, and when I arrived home I put my vehicle in park and turned the vehicle off. However, when I took my keys out of the ignition and took my foot off the brake, the vehicle began to roll forward. I quickly engaged the brake and the car stopped. I took my foot off the brake again and the car began to roll again. I then attempted to engage the brake and start my vehicle. No luck. The engine would not even turn over. Additionally the gear shifter is locked in the position that indicates the vehicle is in park. Even when I put the keys in the ignition and turn them as if I were starting the car the shifter will not move from the park position. So here is what I have tried. With the help of my owners manual I was able to take the panels off of my center console where my gear shifter is located, I was able to override the locking mechanism that was keeping my shifter in the park position, and move the shifter to neutral. I attempted to start the vehicle in neutral. No luck. I moved the gear shifter back into 2nd and then all the way forward to park. I did this a few times and then attempted to start the vehicle again in both park and neutral. No luck. From here I turned my attention to the internet in hopes that I would find a clear explanation on how to fix this issue myself. No luck there. I got some clues in a forum similar to this that the problem could be either my "neutral safety switch" or my "inhibitor switch." I saw a few posts debating whether or not an automatic transmission (AT) vehicle, such as mine, did or did not have a "neutral safety switch." At this point I called my father and he agreed to come over and offer any help that he could. Together we were able to locate what looks to be my vehicles "neutral safety switch" and from there we were able to manipulate this switch by pushing what look like shifter arms in a clockwise fashion and this allowed the vehicle to start up. However, even with the vehicle now on, the problem persisted. I was not able to move my gear shifter from the park position. I overrode the locking mechanism again and moved the gear shifter into reverse and then drive but this had no apparent effect on the vehicle. I would really like to find a solution to this issue and do the repairs myself. I appreciate any advice or comments that will help me find that solution. Thank you in advance.
- 7 replies
- neutral safety switch
- please help
(and 2 more)
Tagged with:
