Search the Community
Showing results for tags '1999 subaru forester'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 2 results
  1. Hello All, Been reading this forum for some time which has been an incredible help with my amateur knowledge of Subarus. I have a 1999 Forester that's really getting up there in miles, currently at 277K. Had the timing belt changed at 258K back in October 2010. As you can tell I haven't driven but 20K miles with this vehicle in the last 6 years, it was a backup vehicle for a long time and would only get run once a week for very short trips, mostly has been sitting in open air (no garage unfortunately). I've done a lot of scouring over the internet and it seems there is a pretty wide range for the timing belt's replacement before it hits 105K miles. I've read that the timing belt should be replaced anywhere from 5 - 8 years. Since this was a replacement belt from a reputable mechanic and not a factory belt, am I overdue for a change or am I good for at least another year? If it helps clarify I live less than 5 miles from where I work and don't plan on driving it much more than to and from work with a few stops on the way. Any help is greatly appreciated!!
  2. hi there i have joined this site with the hope that some MECHANICALLY MINDED AND EXPERIENCED people can give me advise on whats wrong with my 1999 subaru forester. turbo, manual model. ok so heres whats happening. recently i have noticed in the last 3 or so months the car wont start as nice and quick as it used too. it was gradually but slowly taking abit more for the starter motor to tick the engine over. last week i noticed the car making a very odd sounding noise on startup.(ONCE CAR IS STARTED IT RUNS ABSOLUTELY FINE) as a few days went by the noise worsened on startup and the car started having abit of trouble getting started. 3 days ago the noise was horrible and wouldnt start at all after doing shopping, it was cranking over but the engine wouldnt start.....i gave it 10 minutes and tried to start it again. still ugly noise while cranking and no start. so i put it into reverse and turned and held the key so that it rolled back as the starter motor cranked, then i hit the clutch and the car started up?????? took the car home and parked it up. i removed starter motor and got another one from another turbo forester and put it in. now the car starts again but i am getting that noise again and the car isnt starting up nicely like it normally would... ive been around to a mechanic who told me to go to a auto electrician and get his opinion and for him to listen to the noise also.. they have given me the thort that it may be the RING GEAR that is stuffed??? i had the iniyial thought that i had brought a dud starter motor. they told me to come home and take starter back off and look at the ring gear....... keeping in mind that once the car is running its fine!! issue is only on startup. DOES ANY1 KNOW WHATS HAPPNING? ANY1 HAD THIS ISSUE BEFORE?? Please help
