Search the Community
Showing results for tags '2 inch'.
I picked up a 95 impreza 1.8L with forester suspension and brakes previously installed (bad engine- swapping in a 2.2L and Delta currently has my cams). I ordered trailing arm bracket spacers and I'm pretty sure the maxxis 27x8.5x14 tires on offset dirt track wheels will clear the spring perches an...
I am trying to install a 2 inch sjr body lift on ea81 wagon and I have a few questions. First, do I need to install new longer custom brake lines with this size of lift? Also, there was no bracket included to drop the rear diff, do I need one if it's only 2 inches? And lastly, where do these pieces...
