Search the Community
Showing results for tags '2.2 L'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. I bought a 2.2 L manual 1996 subaru legacy outback last year. It consumed a lot of oil and puffed a little blue smoke coming down steep roads or hills. I flushed the rdiator when I got it, oil and filter change, brake change, valve cover and seal change, air filter. drove it for about 2 months when it started to hard idle. Noticed if i was coming to a stop in any gear other than first it would die, and I could keep it from dying by pushing in the clutch almost from deceleration, even if going 30mph. The hard idle became a bucking when slowing down and at times when speeding up. changed the 02 sensors. nothing opened up the cat to find it had melted into a block and was clogging the muffler. a relative broke most of it out in the cat but didnt clean out the muffler further back. hooked up to to read the codes and got: p0500 vehicle speed sensor (speedometer doesn't work) p0201 injector circuit cylinder 1 p595 iac system p0301 cylinder misfire un hooked the iac and it instantly breathed better it is still not connected still uses a lot of oil now puffs out blue smoke at high rpms other than 5th gear and occasionally at start up. car is choking on itself really bad I have looked up so much stuff online and am at a lost. Any help would be very much appreciated
