I'm running out of ideas to fix a persistent vibration in my auto H6.
Symptoms are:
1 Occurs at various speeds, most noticeable above 40kph.
2 Putting it in neutral does not seem to help, though perhaps a little.
3 Vibration is reduced when under load or accelerating.
4 Whole car vibrates, but not severely, can't locate source.
5 Unaffected by engine speed.
What I had done:
1 Reconditioned transmission installed a year ago and seems very good. Oil levels good and clean.
2 Tailshaft balanced and U joints replaced.
3. New front and rear wheel bearings.
4. Used rear diff installed.
5 New aftermarket front driveshafts.
6 New front control arm bushings and ball joints.
7 New front sway bar D bushings and new sway bar links
8 New front struts.
9 New front strut top bearings.
10 New rear bushings for rear upper control arms
11 New tyres and 4 wheel alignment.
Any ideas? Rod
