Search the Community
Showing results for tags '2000 outback'.
Unlike some people 2K - 3K is a lot of cash to me. So i like making the best decisions I can make. I have never owned a Subaru and I am not against owning a high mileage vehicle. I am considering a 2000 outback wagon, with manual transmission. the Engine has been swapped out and the "newer" engine has 120K on it. Everything looks good, drives good, basically clean with the Limited trim package. If I can get it for 2k to 2300 does that sound like a good deal? It also has 4 brand new tires and a new battery !!! thanks, -steve
Need some advice, I have a Subaru Outback 2000 with over 250,xxx Miles. Codes: P0420 and P0303 When I initially ran the reader it said the O2 sensors were bad, both front and back. I replaced those hoping it would eliminate the 420 code also but it has not. Though, the O2 sensor codes did go away. Any advice on what would be good to check before outright replacing the Cat? As for the 303 code I was advised that this is probably related and will go away once the 420 code is eliminated. The car doesn't run well. It lacks power and often stutters while accelerating, sometimes almost violently if the AC is on. My Battery has had some issues with a bad connection that I have to tighten frequently because someone overtightened it. Anything helps!
- 12 replies
- 2000 Outback
- P0420
(and 3 more)
Tagged with:
