Search the Community
Showing results for tags '2003 outback'.
  • Search By Tags
    • 2003 outback ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 10 results
  1. after 17 years of ownership, today I discovered that the DS window defogger vent in our '03 OB can be flipped to direct upwards to the windshield!!!
  2. Hello! I have a 2003 Outback R Premium Pack 3GEN Auto AWD MY04, I have taken it to both an independent mechanic and the Subaru dealership in the town across from me. Both have come to the conclusion that the abs module/pump (part number 27596AG010) is stuffed. Subaru so far have been the only o...
  3. I have to get an engine together for an 2004 Outback EGR 2.5L. The old engine has a hole in the case. I have a good short block from a 2002 Outback that doesn't have EGR heads so I want to remove the EGR heads and install them on my good short block. I figured it would be best to mill those heads an...
  4. Good Evening, I just joined the forum, thank you for having me. I loaned my 2003 Outback to a friend in need recently. While he was driving on an exit ramp off the turnpike it broke down. No warning lights came on before or during the break down. He could not get it to start back up. Also...
  5. Good Evening, I just joined the forum, thank you for having me. I loaned my 2003 Outback to a friend in need recently. While he was driving on an exit ramp off the turnpike it broke down. No warning lights came on before or during the break down. He could not get it to start back up. Also...
  6. Hi, all, Need a little advice. This is a 2003 Outback Sedan with H-6 engine and automatic. One tire in front developed a ply failure and I bought 4 new, all were to the wear bars. I laboriously took off the fronts one at a time and carried them down to a tire shop for mounting, now the front axl...
  7. This is a follow up to a thread from last week about replacing a front caliper and recommendations as to used, new, brand, etc. I started out with a garage that told me my front passenger brake was sticking, the cause of our 2003 base model outback 146k miles, pulling to the right. They recomme...
  8. My wife's 2003 base model Outback 2.5L Auto, AWD, U.S. model 146K miles. The front right caliper is dragging. Dealer says it needs replaced to the tune of caliper, pads, rotor( gouged ) about $600. I'm willing to tackle it myself. My question after determining it doesn't just need cleaned & lube...
  9. What would you do? Looking for some advice / thoughts regarding my noisy Outback transmission. Car is otherwise in good working condition and runs well. I'd like to keep it as long as possible before replacing it. My 175K miles 2003 Outback transmission began whining about a year ago, and has...
  10. Found 2003 outback limited ed.280,000 mi.new heads alot of other work.body good.like 800 bucks.just thinking about the hi miles.etc..opinions
