Search the Community
Showing results for tags '2009 obw'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. My PowerSteering (PS) pump bearing showed signs of going bad with a ticking steel on steel noise especially in cold weather. Now I got one from a donor car but of course to the same model same engine number the pump is slightly different (only mine is 9 months newer). (mine is last BP 2009 OBW series EU). The main housing of the pump looks exactly the same. But then: 1. The one piece where the piping connects with the elbow has a different angle, pointing more forward. I was thing to just undo the screw and use the elbow one I have on car now. 2. The other piping connector is more a mystery, mine has the banjo bolt directly on the housing, but here seems a nut is there. Can i just remove that nut? and then put my current banjo on the housing. Or, do I have to put the banjo on top of this nut (seems to fit) Then the bracket that holds the cover is bend (donor had to hood damage, ran into a trailer after it was rear-ended), but can easily transfer my own as well. Will this work?
