Search the Community
Showing results for tags '3rd eye'.
...before it happened. Or at least it should have. Hindsight is 20/20. The 3rd eye harness is very close to the battery. Rats were hungry and ate some of the insulation off of the red and black wires in the harness. Went to pull the battery to use in a different car; took off the negative terminal first, and then wrecklessly set it down in front of the battery, with the positive terminal still connected. Before I could undo the positive terminal I heard a "snick" similar to a fuse popping. The negative terminal had brushed those exposed wires... either the red, or black, or both. Now the highbeams work, as well as the "beam" icon on the dash. But once the 3rd eye button is pressed, neither it or the "center light" icon on the dash work. The 3rd eye was funtional before, door and light. McBrat, the one who built the straight-axle '82 Brat, had a diagram on "Indys World . com" but unfortunately that site is no longer up. What kind of tests can I do? Did I blow a relay or worse the 3rd eye?
Wiring 3rd Eye/Passing Lamp/Cyclops
smithofnico posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
Attaching 2 wiring documents (PDFs) from the old Ultimate Subaru site so they don't get lost. Original Authors are: Wagon78 Chris Lantieri Using Center Light Wout Relay.pdf Wiring Instructions for DPDT relay for center lamp.pdf- 2 replies
- 3rd eye
- Passing Lamp
(and 3 more)
Tagged with:
Hi all. I am looking to setup a 3rd eye light with a DPDT relay setup. This will be in an '81 model year, EA81 wagon. So positve switched system with glass fusebox. (EJ swapped w/internal regulator ALT.........but that doesn't/shouldn't affect the lighting setup) There was a writeup in the old USRM on the indysworld server......but sadly the link is now 404. So i am looking for info on this. Where is the factory timer box located? Anybody got specs on this? I've got an 82 model Serivce Training Update that has a basic diagrahm of the Lighting w/ third eye......But it is showing the Ground switched setup of later model type......with the 3rd eye as an auxillary Hi beam, rather than a "passing" light which can be turned on anytime. And it has no wire colors, or locations of connector pinouts. This is useful.....and I can post a scan of it for others.....But I really need to find good info on the early setup, where the timer is, and how to bypass/replace the original with a DPDT switch or relay.... I will make this a Write-up with info and diagrahms thorough. If I can get it all compliled and figured out on the test rig.
- 8 replies
- Center lamp
- passing lamp
(and 3 more)
Tagged with:
