Search the Community
Showing results for tags '4 wheel drive'.
o/ I tried a bit of searching before hand and didn't come up with anything similar to my problem, and NASIOC didn't have much help other that the direction to this site. (Which I'm ecstatic about.) I bought a 1985 GL from my in-laws, I found the car a year ago and was about to buy it when they said they needed it more, so I let them snatch it up with the intent of buying it from them later on. Well, that time has come and now it's mine. They drove it maybe 2,000 miles in the year they owned it and did improper maintenance. Now it's got a dead lifter and 2 blown head gaskets. I'm not very concerned about those two issues, they're easy fix's for me. I am however concerned with my 4WD system. FWD works perfectly, it'll even do a one tire fire if I'm not easy on the peddle. 4hi it makes a ton of gearbox noise from the center diff, and it feels like one of the rear wheels locks up and just drags, all while going straight, I haven't dared to turn. 4lo makes the same noise however it seems to work just fine. I haven't really tried 4lo that much due to the fear of it breaking on dry pavement. The weirdest part of all this, is it only goes back in 2wd if I'm going in reverse. It refuses to go back while moving forward. If you've got idea's before I start cracking the box's open, I'm all ears.
First post to this board. Just bought a 84 GL. Only one of the four wheel drives works. When the normal 4x4 light is on it won't engage gears. It's like I'm in neutral. When I pop it to 4 lo it works but the guy that sold it to me said he thought that was the only 4 wheel option and he took it up to speeds much higher than 4 low can get to. It is a Manuel, and has a ea81 brat motor in it. I would like to get both working. Just wondering how big a fix this might be. Thank you.
- 19 replies
- 2
- 4 wheel drive
- 1984
(and 2 more)
Tagged with:
