after serviceing my duty c and clutch packs my car basically refuses to move it will catch in reverse speratically and does not feel like its shifting into any gear other than neutral. last time I did a drain and fill I used valvoline maxlife full synthetic atf and then filled with the same after this service and its like nothing is locking up, if and when I do get enguagement it feels like its slipping slightly. I drained more fluid than I should have and it drove more normal then checked and filled symptoms got worse.
I drained all the fluid I could dip stick registers as empty then refilled to cold full level. problem is just the same car in just about any shift possition wont move and will sometimes catch if given gas. there was a point that shutting the car off, restarting and imediatly shifting into another gear would let me move the car (how I got it back to its parking spot)....
PLEASE HELP!!!
Thanks
