Search the Community
Showing results for tags '4th gear'.
I have a 2005 Saab 9-2x Aero (WRX) 141,000 miles, completely stock, with the 4EAT automatic. Under full throttle, at about 70 mph, it will shift from 3rd to neutral (and redline) rather than shift to 4th. I must let off the throttle and give it a few seconds to find 4th gear when this happens. Under normal acceleration, it has no problem going from 3rd to 4th gear. I have just replaced the transmission fluid and filter (using genuine Subaru stuff) and still the problem persists. I have never driven anything with an automatic transmission before and really don't know where to start with this, it is also difficult for me to find anything on the web about this exact problem, so any help would be appreciated. Thank you!
I recently purchased a 2010 Forester with 95K miles and a manual transmission. The fourth gear would grind a bit when shifting fast, and I would have to make sure that the shifter was pulled hard all the way back to get it into gear. If I didn't the gear wouldn't engage and the gear would grind like it was sitting on top of the input shaft. I changed the fluid and it was black coming out. I put in 3 quarts Redline lightweight Shockproof and the rest Motul 300 75w-90 and it got rid of the grind. I do still have to really make sure 4th gear is engaged though. Could this be a worn shift linkage or bushing to replace that will tighten up the spacing or slack in shifting?
- 6 replies
- MT
- manual transmission
(and 2 more)
Tagged with:
