Search the Community
Showing results for tags '5 speed'.
  • Search By Tags
    • 5 speed ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 12 results
  1. I aquired this cool little wagon a little while ago From JAmacT. I thought the motor had issues and the 5 speed had no reverse But the price was right FREE. See ad here http://www.ultimatesubaru.org/forum/topic/155635-free-86-subaru-dl-manual-5-speed-4wd-wagon/?hl=free So after towing her fr...
  2. (updated with the answer) Symptoms: The transmission on my 5 speed 2000 Legacy GT (AWD) sounds like an angle grinder or go-cart (grinding/buzzing/putting noise). Started making noise overnight, in every gear and in neutral, sounds like something rotating/grinding and is proportional to the...
  3. I have a 2003 Forester 5 speed already out and split to replace the input shaft seal. My question is on the seal I received from Rock Auto. I've attached a picture of the two, the one on the left is the original. The one on the right came from Rock Auto. As you can see, the one from Rock Auto...
  4. I have a 2002 Forester 5 speed AWD. When accelerating from a dead stop, letting out the clutch pedal, it frequently shakes the car like it is possessed by demons. I combat this by revving the motor a bit and/or double clutching. It does not do it once the car is moving. Also, it does not occur when...
  5. I have an 1983 gl (ea81/4speed tranny) and was wondering if the 5 speed tranny from an 1989 (ea82) would fit? I know about the normal modifications for a 5 speed swap. I was mostly wondering if the year difference would affect the swap...
  6. Hi names Kellogg im 19 years old, i took out my buddys motor 2.2 outback wagon legacy 5 speed, i got it all done and put back together within a day. but now it smokes white smoke. im sure thats because of the chainsaw gas he put in it cause it was almost empty. but im more worried why wont it shift...
  7. I have a 99 OBS and I love it except that it's not a manual. it has 270,000 miles but I just replaced a lot of parts and the only thing wrong is a slight exhaust leak and play in the rack and pinion. My friend is selling a 98 legacy outback with 210,000 miles and who knows what maintenance history...
  8. Just bought a 2nd Generation 1988 Subaru GL 3 door hatchback 4 speed manual transmission with dual range (4 hi, 4 lo) with an EA81 engine. I've been searching this forum, but haven't found alot of info regarding the benefits of swapping my 4 speed manual for a 5 speed? There are alot of posts about...
  9. Hi; I have a 1984 turbo wagon with an automatic trans. The trans shifts and seems to work like it should, but I have a bad crunching and vibration when the car accelerates. The former owner had new axels installed so not them. I pulled the axels and the splined stubs appear to be loose, maybe someth...
  10. is there a 5 speed transmission you can hook up to an ea71 engine in a 1980 brat? if so what is the easiest way to go about getting it done?
  11. Hello, I have a 2002 Legacy L Wagon 5spd with 195k on it and it's in great shape, runs strong and I love it. I have put many hours into this car mostly in preventative maintenance (keeping the rust away is yearly task up here in SaltLand!). But anyway... my issue: A month or so ago I was pulling...
  12. The Car: 1984 Subaru Brat EA81 Turbo - 5 speed D/R swap (3" body lift, increased tire size) ........................................................................... The issue: 1984 5-speed D/R Transmission has a small amount of play (side to side, up down movement) on both of the fr...
