Search the Community
Showing results for tags '5 speed transmission'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. OK I have read a lot about the side differential retainers and how they set the differential pre-load. My problem is they keep shattering on my transmission. First lets give some history. I removed the engine and transmission to rebuild the motor, and found that the throw out bearing was shot. I also found that there was a lot of play in the input shaft. So my son and I decided we were going to attempt to rebuild this transmission. We watched several videos and did a lot of research into disassembly and reassembly of the transmission. Once we took the transmission apart we found that one of the bearings on the input shaft was toast. Since we had the transmissions apart we decided to replace all the seals, o-rings and gaskets. This meant removing the Side Differential Retainers, knowing that not getting them back into the same precise location would change the differential bearing pre-load and pinion gear backlash we marked a tooth and the housing of the transmission with paint so we could realign it to the same place as before the tear-down. We counted the rotations it took to remove them and reversed the process and reassembled the transmission. Everything was going fine on the test drive until I got back and saw that the car was leaking gear oil out of the side of the transmission. Upon closer inspection we found that the Side Differential Retainer was broken and the seal was destroyed. Thinking that we put the wrong seal on the wrong side, we replaced the retainer and the seals making sure that the right seal went in the correct side. But after the second test drive the same thing is happening. Can anybody give me any idea what I am doing wrong or some place that I can look to find out why this keeps happening. Thanks
