Search the Community
Showing results for tags '5-lug'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Hello, Fellow Subie Owners! Long time no post! I have a question: PandaWagon, my 87 GL Wagon with an EJ25D and 5-lug swap is my RallyX/backup daily car. I am at a quandry with the suspension setup on her. Currently: IMG_5067 by subynut, on Flickr Front KYB AGX with 200lbs/in Ground Control coil overs with no preload RX Sway Bar Whiteline Strut Top Mount with extra Negative Camber and Positive Caster Alignment set to about -2* of Negitive Camber and 0 Toe. Legacy Bump Stops with 2/3 of it cut off for extra compression. Rear: Koni Yellow with 250lbs/in Ground Control coil overs with no preload XT6 Sway Bar RallyX Tires are 195/60R15 Cooper Weather Master Snow tires. Street Tires are 205/60R14 All Seasons. Her front is sitting pretty close to 2WD height with the street tires, which I like how she sits and she handles amazing on the street! The rear could come down some, but I haven't been able to do that without basically sitting on the bump stops in the rear. Which makes the rear unpredictable while on the race course. :/ She handles pretty decent on the RallyX. Untitled by subynut, on Flickr But! She's bottoming out the front suspension on decent bumps at the RallyX. Closer wheel arch spaces: Front: Untitled by subynut, on Flickr Rear: Untitled by subynut, on Flickr I have about two inches before the bump stop on the front. I've tried 250lbs/in springs, but at those rates, she's too bouncy and her nose is going airborne. I've played with the shock setting, but all I seem to do is make the bouncing worse. The 250s work great at high speeds, but that's way too fast for RallyX. Rear is ok as far as the springs, but I'm having a challenge with shocks. The Koni's appear to be wearing out. They're not dampening like they used to. (Abount 2.5 seasons of RallyX and some AutoX on those. I understand that travel is a biggie for RallyX, but I don't want to lift the suspension anymore than 4WD height to keep body roll under control. (Preferably, I'd like to keep the suspension at 2WD height. But I don't know if that's possible for RallyX) So, this is my ideas: Add preload to the front coil springs to lift the nose some Concerns: Will I bind the coil spring before hitting the bumpstop? (I'll get a picture of the coil over in it's current state later) 225lb/in springs Concerns: Will that still be too much spring? STi front springs Concerns: Will that lift the nose too much? I don't have STi springs or the 225lb/in coilover springs, so, I'm thinking I'll try adding preload and see if I can mimick the RallyX on the street. Am I on the right track with just adding preload to the front coil overs to lift it a little?
