Search the Community
Showing results for tags '5mt center diff'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. The patient: 1999/2000 RX Liberty wagon (EJ251) 5spd manual. Issue: swapped in second hand gearbox (pick a part special!) only to find the vehicle now has a wobble like feeling from the front left when under acceleration, becomes worse with heavier acceleration. All other times the vehicle generally feels unsettled. Both of these issues were not present with the last gearbox. The other issue is that I have that totally awesome “catch-let go-catch-let” go feeling or experience when turning tight such as when performing a U turn - classic symptoms of a dead centre diff.Questions: 1) can a stuffed centre diff create the issue with the front end that I’m experiencing?2) can the viscous gel stuff leak from the viscous LSD housing, and if so, what does it look like? Question 2 was asked because after stripping down the old box that was replaced, I’ve found a ball of what looks like silicone near the front diff area, and in between the drive and output of the centre diff is the same sort of material. It does seem like silicone but it’s just odd. This gearbox has presumably done over 400k km now - if it hasnt been changed at some point. It was swapped because of a bearing noise and it was slipping out of gear (possibly due to shot pitch stopper rod and gearboxs mount).Upon rotating the centre diff it seems the noise is in the rear bearing. This centre diff is good so itll end up in the wagon either way - unless that grey material is the viscous gel stuff. The plan is to build one good box from the two. I’ll be replacing the front diff bearings, all seals and most likely use the centre diff bearings from the replacement box as there’s zero noise from this box, other than the noise when performing a U turn. Cheers Bennie
