Search the Community
Showing results for tags '84 gl'.
I have a 1984 gl 4spd duel range. I have a clean 92 ej-22 sitting in the garage. A friend will sell me a harness and ecu for 50$. I still need a fuel pump, clutch,trans plate, re drilled flywheel, high pressure fuel line, front wheel bearings, fluids, and a cv axle. I have about $500 saved up. Can i get the swap done with this much money? i cant afford to have my car not be usable for more then a few weeks. Any input would be appreciated, thank you.
Im gathering everything to put a freshly resealed 90 ej22 in my 84 gl. I currently have a 4spd d/r. At first i was just going to use the adaptar plate but now it seems like the 4spd is giving out. It would be for a street/rally car, so i thought itd be cheaper and easier to swap to awd. I've searched through alot of threads but haven't found any good info on installing the new trans. Anyone have some tips? Thanks
