Search the Community
Showing results for tags '85 gl'.
Just picked up this GL off a friend, cause I have always wanted one. It has 231k miles on the odometer. Just would like some advice on what to check out first as far as fluids, spark plugs, ect. Also passenger rear CV axle is broken and needs replaced, and the 4WD says it engages but doesn't actually work. Any thoughts on that would be nice. Located right now in Battle Ground but will be moving up near Tacoma soon. I am very excited to have a fun little wheeler. I have a set of 6 lug Toyota wheels I'm going to re drill for the God awful bolt pattern. Not sure on how lifted it is but plan on throwing some general grabbers on it. Any advice on the size would be awesome as well. Thank you again.
I'd like to get some of these knockouts on my 85 GL Wagon dash filled in, to make it look more complete or 'loaded'. Plus, I am having zero success with my weber choke (had it apart, tried everything) ...so if you guys can help me out with what goes where, and what it looks like, please...all those blanks kind of bug me. Anyone got a pic of the most loaded dash? The Subaru 'correct' manual choke handle? any other options that are missing/blocked? I will have to live with the stack of empties on the gauge housing, since I won't have air suspension, and my cruise is the dealer type -although 'dummy buttons' (or rocket launchers)-might go in to fill it up. If I know what I'm looking for, it will be much easier to find, or request in the wanted section. TIA
