Search the Community
Showing results for tags '90-94'.
Hello, I have a 1992 Legacy Wagon, EJ22, AWD. A few days ago the motor would not fire up and has not fired up since. The wagon has not had any motor work done to it for over 3 years. It ran and drove great over these past 3 years. The wagon has never been in an accident. The timming belt was replaced 3 years ago. What I've checked: -Fuses (both under the hood and Under the dash) -Ran the codes (24, 11, 13) -Inspected crankshaft position sensor. Tested sensor and found it to be working and within spec. -Inspected camshaft position sensor. Tested sensor and found it to be working and within spec. -Swapped out both sensors with known working ones just to be sure - no change in problem. ALSO did this test - disconnected crank sensor, connected cam sensor, sprayed fuel into intake, turned over motor, no run - disconnected cam sensor, connected crank sensor, sprayed fuel, turned over motor, no run. - connected both sensors, sprayed fuel, turned motor over - runs like a frickin champ. *** Cant test the Air Control Valve (code 24) because the Haynes manual does not have that part listed in the book. -Inspected Coil, All plugs are getting spark and sparking properly when the motor is turned over. -Inspected Fuel Filter. Good volume of fuel flows through filter. -Fuel Pump. I did not have the proper gauge to test fuel pressure, so I replaced the fuel pump with a brand new pump. Fuel filter sock is new to. -Tested fuel injectors, all 4 have proper ohm reading. What I've discovered is the fuel injectors are not pulsing. -I tested each electrical lead and found that there is no power getting to any of the injectors. When I switch the key on, I should have 12V. I dont know what else to look at. Any suggestions? Thanks.
