Search the Community
Showing results for tags '93 impreza'.
Greetings from central il - I'm 56yro autobody tech with 8 children -all with my wife of 34yrs -I picked up white fang-93 impreza last week for $850 -needless to say I'll be seaching here alot -you guys prob got alot of history on these little jewels -thanks in advance for all your help and if you do have basic auto questions feel free to hit me up -i've been in autobody all my life -cheers Denny
Car wouldn't start after parking it for a 1/2 hour on a slight hill. Had it towed home. I determined the timing belt had failed by removing the right cover and placing a mark on the belt...started the engine and it did not move. Took it apart, lined up my marks but forgot about the #1 cylinder thing~ redid it...using a gun cleaning rod dropped down into cylinger #1 and putting a mark on it in line with the edge of the body to detect the upstroke. When it was out the farthest, the arrow on the crank sprocket was right where it should be. I cranked the right hand side clockwise to bring the mark up. The left cam pulley is freed. I positioned the belt using all the marks, installed the tensioner and bottom pulley, pulled the pin and nothing moved out of position. I put the crank pulley and bolt back on...(runs better with it on) and it wouldn't start. Is it possible that even though it seemed cylinder 1 piston was all the way up that it was actually up on the exhaust stroke? Am I not understanding this? Also, I think I need to clear some codes, because I questioned that the MAF may have failed too...and I remembered I had another Subaru that would run with the (bad) MAF sensor unplugged. It wouldn't run well, but it ran. In unplugging it, maybe I threw up some codes, and because the car is so old, I don't think there is a port to plug in my diagnostic tool. Could it be the crank sensor? Car aaaaaaaaaaaalmost wants to fire. I changed the filter as I hadn't since I got the car. Key on, fuel shoots out. This is my third timing belt change and I can't help but think there may be something else wrong.
- 8 replies
- 1.8L
- 1.8L timing belt
- (and 7 more)
The morning of the day I purchased it, the door handle broke on the driver side before I picked it up :/ Any resources? I have a few junkyards in my state, and was wondering how long before the doors changed on Impreza sedans/hatchbacks. Any info very much appreciated!
- 1 reply
- 93 Impreza
- door interchange
(and 2 more)
Tagged with:
