Search the Community
Showing results for tags '94 loyale'.
94 Loyale wagon starting/running issue
risonm92 posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have recently acquired a 94 loyale wagon. It has issues starting and running. It had stale gas in it i drained it out as best i could and put about 2 gallons back in it. it has new plugs good spark and 50lbs of fuel pressure but will not start easily at least. The only way i have been able to get it started is if i put a little gas into the throttle body unplug the injector solenoid turn it over for a minute then it will start to fire poorly at wich time i plug the solenoid back in and it will stay running poorly for a short period of time untill it dies. if i leave the injector solenoid plugged in itll turn and turn and it will act like it starts to fire then itll just continue turning over with no fire at all it seems like its flooding itself out but i honestly have no clue any help or suggestions would be greatly appreciated. Also it seems to help when you tap on the egr valve when try to start it. -
trying to eliminate my TOD (tick of death) or lifter tick and looking into maybe just making some adjustments along w/ using a heavier weight oil along with an oil treatment, but not sure i can make those changes if the rocker-arms are hydraulic. it would seem that based on the relative simplicity of the Loyale's engine, they'd be solid, but not sure. anyone got a firm answer for me? thanks much, Glen
- 13 replies
- 94 Loyale
- Loyale 3AT
(and 5 more)
Tagged with:
