-I have a 95' Legacy L wagon with a low roofline. I was at a local yard and came across a 97' Outback wagon. Even though it has the raised roof up front, the actual hatch appears identical and it seems the roof was sloped down enough that they are interchangeable? Is this correct?
-Also, to remove a hatch, where is the wiring plug located at so as to avoid cutting the donor's wiring?
-I take it one side (there are the 2 rubber boots that protect the wiring, on opposing sides with hatch raised) is wiring, and the other side is for the windshield washer hose?
