Search the Community
Showing results for tags '98 legacy'.
INFO: 1998 Legacy L Sedan, Automatic, 2.2l 258k BRAKE INFO: 4 wheel disc / ABS / single piston So, just got done putting new calipers, brakes, and rotors on the rear of the sedan. Prior to replacement, every time I turned a corner, typically turning right, the RIGHT REAR made a grinding sound. I figured it was brakes, since there was some wear marks in the rotor. However, now that it's all done, it's still there. Wheel isn't bent, tire is new. I'm thinking bearings? Or maybe axle is bent?
Hi everyone, first time poster. I have a 98 Legacy 2.2 and the coolant fans won't come on no matter how hot it gets. I disconnected the pigtail from the temp. sensor to check for voltage at the plug and when i turned the key to the "on" position the fans both came on. When I plugged it back in, both fans shut off. The volt reading was 5 volts on one side of the pigtail plug, and 10 volts on the other contact. Does this mean the temp sensor is bad? Thanks for the help.
