Search the Community
Showing results for tags 'Clutch replacement'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Hi, I have a 1997 Subaru Legacy Brighton Wagon with a 2.2 engine. I am trying to replace the clutch and have run into a bit of an issue. My friend who is helping me said that after he removed and re-installed the new clutch disc clutch cover and bearings. Almost put everything back together then tried to install the clutch cable it appears that the fingers (diaphragm springs) are depressed (flat). (not sure if that makes sense, I am not a mechanic, but willing to learn) I have compared a couple models of replacement clutches and they look the same, one from LUK and the other from Exedy, no difference between the 2 manufactures, Is there something we should be doing that we are missing. I understand that the new clutch disc is thicker than the older one due to wear. I thought maybe I needed a different flywheel, but apparently its fine also. Looking for suggestions. Thanks.
