I am new to the forum and I am sure this is somewhere within the topics. Any help would be appreciated.
A little history, I own a 2007 Subaru Legacy w/ 2.5 H4 SOHC and 57,000 miles. I just had the head gaskets and sparkplugs replaced. I had the expensive head gasket oil (no coolant) leak. Took it on a road trip and averaged 30 miles to the gallon. After returning home and putting gas in the car, I got a CEL and flashing cruise control warning lights. Checked it with my Actron and received the P2097 post cat fuel trim sys too rich bank1 code. I then checked the live data, my Cat is running temp is 800+ degrees, the upstream o2 is 3 volts the downstream is .8 volts. Any ideas what it could be or should I check something else in the live data?
