Can someone please explain the function/importance of the small plastic black box mounted on the left kick panel area, it is accessed behind the fuse panel and has a wide white connector with 14 wires (if I counted right). I picked up a DL 4WD wagon, SPFI, manufactured in 01/88. It dosen't run (yet). And there is a yellow wire w/ white stripe fished up through the top left portion of the firewall. Looks like they had it connected to something in the engine bay. Ground? Power? Anyways would like to know if it has anything to do with why the car currently isn't running. I believe it's a spark/electrical issue. Belts are good. Tried starting fluid. And have swapped out both the disty and coil from a running Loyale. Only trouble code is 21 (temp sensor circiut). Sorry no pics of the box It' hard to see in there!
The wire in question (Ylw/wht) originates from this black box, so why was it brought into the bay?
