Search the Community
Showing results for tags 'EA 81 1600'.
Hey there guys and gals, I am the proud owner of a 1986 2 dr FWD Hatchback with 122K on the car. I bought it from its original owner so most of the original parts that came with it are starting to wear out and require routine matience. I'm working on my clutch and I am looking for a replacement flywheel seeing as the one I have currently installed has already been machined once and I always plan ahead for the unexpected. The only problem I have is that this part is hard to come by. The issue is that I have one of the rare FWD only models that was just sort of thrown together at the end of the model year from leftover parts to create a sellable product. Subaru stopped manufacturing the car model in 1984, but kept selling the vehicles with a new model year on them until they ran out. As a result, I've run into my share of issues when tracking down parts and have spent many a weekend in the wrecking yards tracking down old donor cars to keep my old gal running. I need the 7 in diameter flywheel. Seeing as not many FWD models were really made and still exist, there is very little demand for and no after market manufacturer for this part. All of the flywheels I've found are the 8 in flywheels that are designed for the 1800 class engine that was primarially put into the 4WD models that came shortly after my model year. I'm fairly confident that I can sand the glazing off of the flywheel with my grinder, seeing as it isn't gouged or warped in any way. However, while it may not be an issue now, in the future if I can't find a replacement flywheel for my engine I may be forced to make a conversion over to the 4WD Dual Range, which might force me to have to upgrade to the larger engine. If anyone has this part or has any advice on what sort of transplanting/frankensteining I can do to solve this issue, please don't hesitate to message me. If there are any other models that carry a flywheel that might be compatible then let me know so that I might broaden my search.
