Replacing the head gaskets on my 92 Loyale. Engine is removed, stripped down, cylinders are removed and on the work bench.
A couple of questions as I progress.......
1. On the cam tower I have read to ensure the use of the metal reinforced O'rings on the cam tower (P/N 13089AA010). Is it just one O'ring per tower?
2. Looking at the Miles Fox video (#21) it shows a large O'ring for the whole cam tower being covered with Permatex grey. Is that O'ring purchased or made? Special material?
3. Are the alignment pins on the cylinders and block removable? Removing them would make it easier to clean the surfaces for the new head gasket. Should I remove them? Suggested technique for removal?
4. Seven Hydraulic Lash Adjusters (HLA's) spin freely by hand, while one is different (spins real hard, sticky, feels like metal to metal contact when it is turned). Seems like it needs replaced. Suggested technique for removal of this Hydraulic Lash Adjuster (HLA)? Can I replace just one?
Happy Independence Day!
Bill
