Search the Community
Showing results for tags 'EGR system'.
Here are the pics showing how my EGR/ASV system was plugged/modified, whatever you want to call it. First is a picture of the entire engine. Look below to where the exhaust would come out. There is a little pipe about the size of a quarter in diameter coming towards the camera, it's been cut and welded shut. The next picture is of the same pipe, just on the other side of the engine, the driver side. Same thing. I was told these pipes are part of the ASV system by someone on a forum here. My mechanic said EGR.. Wouldn't these pipes normally lead up to the EGR valve somehow so it can redirect exhaust to the intake? On the first pic, see the bolt directly above the pipe I'm talking about. What engine port is this. There is just a bolt instead whatever went here. A sensor perhaps? The third picture is a closer image of this same bolt/port. It is right by the passenger-side rear spark plug. The next (fourth) picture shows the EGR valve close up. As you can see, the (intake?) hose for the valve just has a bolt shoved in it. The fifth picture is just a view from a little farther away so you can see where the valve is.. The sixth pic is of the EGR valve, looking from the passenger side. This shows another engine port on the intake manifold where a bolt has just been shoved in. What is this port for?? The horrible part is that I don't know if these "bolts" can be easily removed. They look like they were welded in.. One last question, the last (seventh) pic shows the passenger side of the engine from the front view. There are tons of attachment points for bolts and what not on this side. What are they meant for?
- 4 replies
- picspictures
- brat
(and 5 more)
Tagged with:
So I just had my engine pulled out of my '83 Brat to replace the rear-main seal. Turns out it didn't even have a rear-main seal. Anyways I also found out that the entire EGR system has been plugged. The EA81 in this car is not original so I was wondering if Brats had an EGR system in 1983. If they did, then my engine has been swapped illegally and won't pass inspection; however, if they didn't, then plugging up the EGR system makes sense and is legal. I need to know fast, so any information would be greatly appreciated!
