Search the Community
Showing results for tags 'Engine Overheating'.
Similarly to chrisw's issue at http://www.ultimatesubaru.org/forum/topic/140703-repair-the-engine-or-buy-another-car/, I am also not sure if I should repair/replace the engine in my 2001 H6 Outback, or just send it to scrap yard (as the dealer suggests). The car just died on me last weekend on my way back from a camping trip. It showed first "CHECK ENGINE" and then I noticed it started to overheat and eventually the engine shut donw. I did not expect this to happen, since my car has only about 130,000 km on it and I cared for it well for 12 years. The Toronto dealer shop (where I usually go to) told me basically the engine is gone - it caused the coolent system not to work properly due to some presure issue. I am not sure of all the details, but that is the gist of what I understood. He said it might be a head gasket, but he suspects that some other part of the engine was broken. I can drive the car fine for about 15 minutes, before I need to stop and let it cool. Has anyone heard of this H6 3.0L engine issue? From what I've been reading these engines should last longer than the 2.5 (H4) engines - since they should not have that many head gasket issues. I allso looked at the used H6 refurbished on http://www.ccrengines.com/, and see they are not cheap (over $6000). This, plus shipping to Canada, makes my feel such a repair is definitely not worh the car's value - assuming it is in good running order (which is not more than $5000). If anyone of you know of good independent mechanic in Toronto (Canada) area who could give me a second opinion, I would be very greatfull. Thanks
