Search the Community
Showing results for tags 'Engine Running Rough cold'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Hello, Here is the situation: Yesterday I noticed and misfire coming from the driver side, and it went away. I do run 93 octane fuel in it. Just put in new factory NGK spark plugs. I have only owned the car for 1.5 months. The care has 99,126 miles on it. I don't drive it hard.. Today, I went out and started it, there was a erratic misfire from the driver side. I took it for a drive, it seem to come and go, then on the way home the "Check Engine" light came on. Coolant Temp normal, Battery Normal I pulled the code using the Ignition Switch, Headlight, Trip/Odometer procedure>These were the codes came up with: P0000, P0302 Also, code C0108 came up, I knew about this one and have already purchased Subaru Driver Side ABS Wheel Sensor and will put it on when I do my Bilstein B6 Struts and Shocks in a few weeks. I will be doing all the Subaru Timing Belt components and Water Pump, & Oil Pump. in the next month too. Is there a Really Good Fuel Injection Cleaner out there?
